Two cylinder Roberts Engine
Old Marine Engine » One and Two Cylinder Gas Inboards » Two cylinder Roberts Engine « Previous Next »
lompocbob
Username: lompocbob
Posted on Thursday, May 31, 2007 - 11:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have found out that the engine I was asking about is a 2 cylinder Roberts. It has a single cylinder head that covers both cylinders and looks to be from the 1920's. Would appreciate any site that I could go to to get more info. on this engine. Thanks Bob
Post Number: 1481
Posted on Friday, June 01, 2007 - 01:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
1919 Roberts
Does it look like this ??
r19
lompocbob
Username: lompocbob
Posted on Friday, June 01, 2007 - 09:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yes it looks quite similuar to the picture. Is this 2 cycle? Is there a place to obtain more info. I collect and show Hit and Miss engines but the only boat engine that I've owned was a Hicks 8 1/2hp. Below is an engine that I will be showing Sat. Bob
1922 Stover 22hp 1007ci
Post Number: 1482
Posted on Friday, June 01, 2007 - 02:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
E.w. Robertson was probably the most prolific marine engine designer, manufacturer, writer etc of his time at the turn of the century through the 1930's.
The late teens through the 1920's the 4 cycle marine engines with the less expensive and readily available Ford replacement parts was quite the rage and Roberston developed some of first, his Company also mfgrd kits to marinize automobile engines.
photos of the engine your looking at would help
get more specific info if possible ? I'll look and see other info I can find .
