Dippy or not?
Old Marine Engine » One and Two Cylinder Gas Inboards » Dippy or not? « Previous Next »
iffy_dippy
Username: iffy_dippy
Posted on Tuesday, June 01, 2010 - 02:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hello, I have been told the engine I have is a dippy model E. I have since been told by a chap that it is not a dippy motor, or that it is a very early dippy. The tag is in the correct orientation, however has been polished to the point it is unreadable, does anyone know a trick to make it readable again, thanks fro putting your thinking caps on and any help, is appreciated, thanks
Post Number: 463
Posted on Wednesday, June 02, 2010 - 09:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can mask the cylinder around the tag and then apply a light coat of black spray paint to the whole tag.
Let it dry thoroughly.
Once it is dry, get a flat piece of wood and glue very fine sandpaper to it, so you'll have a flat mildly abrasive surface.
Then you carefully sand the surface of the tag. You want to remove the paint from the high spots, but leave the background black.
This should reveal the info on the tag.
A light hand and patience is a key ingredient.
keith
Username: keith
Post Number: 297
Posted on Wednesday, June 02, 2010 - 10:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can also rub Brasso into a smooth flat piece of wood and then rub the tag. Less abrasive. Pictures of the engine and shape of the tag would help identify it.
iffy_dippy
Posted on Wednesday, June 02, 2010 - 11:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hello, thanks for your ideas, I will give them a try. I tried to send some pictures, however I will try again, Thanks Mike
Post Number: 465
Posted on Thursday, June 03, 2010 - 12:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You should be able to see the name of the company around the bottom half edge of the tag, if it is a DisPro engine.
