Lockwood Ash model 41
Old Marine Engine » One and Two Cylinder Gas Inboards » Lockwood Ash model 41 « Previous Next »
castironacres
Username: castironacres
Posted on Sunday, February 10, 2008 - 12:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello,I was wondering if anybody could help with some info on a lockwood ash 41. Was a serial number stamped anywhere if the tag is missing? The carb that came on this engine was white or pot metal and has crumbled in to several pieces. On some old threads it was mentioned that a holly NH was right for the 41. It also said that a model T carb was right(makes sense,used other T parts). Any Ideas? Lastly The threads said that a Bosch high tention mag was used before seral #1200 and a wico used after #1200. Anyone know how you could tell the difference and what model bosch or wico were used? thanks for any help you might have, Mike
Post Number: 329
Posted on Sunday, February 10, 2008 - 04:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yours looks like it would take the later mag, the earlier wasn't a rotary, it was a snap type that worked off the water pump. The ones I've seen had the Model T carbs. The 2 cycle L-A had the # stamped on the flywheel end of the crankshaft.
