Prop Wanted
Old Marine Engine » One and Two Cylinder Gas Inboards » Prop Wanted « Previous Next »
sbumgarner
Username: sbumgarner
Posted on Tuesday, September 23, 2008 - 10:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for a propeller as follows:
Chrysler Outboard Corp, Hartford, WI, 42H9F, 4hp, also called Force. 4750-5750 RPM range. Serial Number 3507. Prop dimensions 7.25x6.5RH, part number 332265. Three blades. No exhaust thru hub.
Can you help?
Stan
