The Vim Motor Company
Old Marine Engine » One and Two Cylinder Gas Inboards » The Vim Motor Company « Previous Next »
coyote
Username: coyote
Posted on Tuesday, February 03, 2009 - 08:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for information on the Vim Motor Company,
from Sandusky, Ohio. Can you help?
keith
Username: keith
Post Number: 231
Posted on Tuesday, February 03, 2009 - 09:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Coyote,
You can do a VIM search on this site.
http://www.oldmarineengine.com/discus/messages/2/10257.html
The above link will take you to one of the discussions on VIM.
Bud Tierney
Posted on Sunday, February 15, 2009 - 06:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Coyote: Just noticed your post: in case you run across references to the Vim truck (Phila, PA), that reportedly built an engine, presumably 4cyl, and the Vim Tractor Co (Schleisingerville, WI), sometimes listed as a one cyl engine builder, I did some research awhile back and didn't turn up any connections; apparently just coincidental use of the name.
Bud Tierney
Posted on Monday, February 16, 2009 - 12:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Coyote: Overlooked mentioning I also found no connection between David Dunbar Buick and his Auto-Vim & Power Co (aka Buick Auto-Vim & Power Co), which became Buick M'f'g Co and then became Buick Motor Co, etc, and your Vim marine engine co.
His Co name was probably a play on "vim and vigor" if that was current usage in that time.
