Marine transmissions for small air co...
Old Marine Engine » One and Two Cylinder Gas Inboards » Marine transmissions for small air cooled engines « Previous Next »
Bob Pittman
Posted on Wednesday, December 09, 2009 - 12:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know a source where I can get marine transmissions for air cooled engines like a honda or briggs?
david_stott
Username: david_stott
Post Number: 34
Posted on Thursday, December 10, 2009 - 06:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bob,
I have a Honda GX160 in a clinker putt putt. Still sorting out some issues re drive line and thrust, but generally it is working well. With a through the hull exhaust. on the water it even sounds like the real thing. I do not have a transmission but have a cone clutch from a blaxland. You can buy a Honda with a reduction box or reduction box with clutch, but it is a centrifugal clutch which needs about 2000 rpm to work, not so good in a boat for manouvering. I am currently playing around with propellor pitch to get the engine performing well. I would be interested in your experience, and how your set up will work?
David.
