Source for rings
Old Marine Engine » One and Two Cylinder Gas Inboards » Source for rings « Previous Next »
lee_billington
Username: lee_billington
Post Number: 17
Posted on Monday, August 01, 2011 - 04:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
OK I've done it have my lathrop apart and my Otto catalog said he wound grind rings down.
and today Mark say I need to order from Niagara
$25 each and 6-8 weeks.
I need 4 x 9/32 rings
is there any other supplyer?
Lee
Post Number: 610
Posted on Tuesday, August 02, 2011 - 08:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Order the 5/16 rings and have them ground locally. We usually remove about .030" from the inside of the rings, they are much thicker than the originals, the heavy wall pressure causes too much drag. This makes the engine hard to start and reverse.
Post Number: 611
Posted on Tuesday, August 02, 2011 - 08:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Check your ring lands, if they are worn you can have the pistons machined and use the 5/16 rings. No need to do all four, two compression rings is all most modern engines use, I had a Nissan automobile down several years ago that only had one compression ring and an oil ring.
johnny
Username: johnny
Post Number: 417
Posted on Tuesday, August 02, 2011 - 10:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Otto Gas Engine Works
Dave Reed 410-398-7340
http://www.pistonrings.net
lee_billington
Post Number: 18
Posted on Tuesday, August 02, 2011 - 10:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my local Mach shop say he'll grind them for me thanks.
it's the ezy things we over look
thanks
Lee
