Dispro at our local show
Old Marine Engine » One and Two Cylinder Gas Inboards » Dispro at our local show « Previous Next »
olarry
Posted on Saturday, April 06, 2002 - 03:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
At our farm show and pull today a guy showed up with a dispro.Lots of brass and about a 10 or 12 inch flywheel.Had compression but was missing the greasers and the entire electrical system.The main bearings where alittle loose and the whole thing needed a cleaning.The guy had a price of $300 on it.I thought that was too much and told him to take it to the calvert show.Was I wrong on the price?
Posted on Saturday, April 06, 2002 - 07:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You made the right call. The missing electrics are not an issue. However the loose mains are.
Posted on Saturday, April 06, 2002 - 11:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It depends - if you have a DisPro hull and device and are looking for an engine - might not have been a bad deal - but by that time you've probably spent a lot of cash already. Having the correct engine is always a good thing.
Loose mains probably also measn that the crankshaft is undersize and has to be built up.
A couple of guys have tried flame spraying but after a year or two of use the shafts fracture in a cone shape. Plating seems to do the trick. There is a crankshaft guy here who can plate up about 80 thou.
mro
olarry
Posted on Sunday, April 07, 2002 - 01:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you polished up all that brass and copper it would have made a pretty display engine,evan if you did not make it run.
Bilpalmer
Posted on Sunday, April 07, 2002 - 09:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I looked at it very close and both places for the grease fittings were stripped out. I was on my way back from picking up 2 PW-27"s from Long Island NY and a M-60 from Annapolis. I went by the show to see what it was like. Had planned to connect MR.Day to about a part for one of my YT-1"s but did not after finding aout his surgery. Left about 10 am and arrive home in Fla at 9 pm.
Bilpalmer
Posted on Monday, April 08, 2002 - 12:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Need to correct something in the other message. Meant to contact Nr.Day And also arrived Home at 10;40 Pm Sat night. Received call on cell phone and was trying to talk while typing. Read wrong line as it was 9PM when I stopped in GA for gas.
Richard Day
Posted on Monday, April 08, 2002 - 12:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sorry you missed me. Bil. If I understand your message you went by the CMM show area and if that is so you probalbly then went over the 301 Potomace river bridge to pick up 95 south. If so you went right by my place. What YT parts are you looking for. I am up an around just no heaavy lifting so I you get this way again give me a shout.
olarry
Posted on Monday, April 08, 2002 - 12:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well then you must have seen my truck sitting right beside with the trusscott on it.Where you(bilpalmer)the fellow who talked to me.
Richard Day
Posted on Monday, April 08, 2002 - 05:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Now I am confused. When did this take place??
olarry
Posted on Monday, April 08, 2002 - 08:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It was saturday aprill 6 and 7 at the fairgrounds in lenardtown.It was our clubs(sampa)annuel spring show.It has allways been farm stuff,so I did not post it on this website.They advertised a sell area and this fellow shows up with one engine a dispro.Two other fellows had 15 or so air cooled engines and one cushman.That was the whole sell area.
Bilpalmer
Posted on Monday, April 08, 2002 - 10:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I saw the trusscott on the truck but the only ones I talked to were at the gate. I was only there for about 30 min. That was Sat morning and I left about 10 AM.
Mr. Day, I will bring the engine with me next time but will contact you ahead of time to get directions and to make sure I will be able to see you. I need a flywheel for it but it is completely stripped down and might not be a YT-1 as it looks a little different from the other 2 YT-1"s that I have. It is close. The only place it has palmer is on the rocker arms. The tag is missing. I have your Email address so will contact you before coming up that way.
Richard Day
Posted on Tuesday, April 09, 2002 - 09:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ok fly wheels I have. Most of the parts for YT-1 are NOS. or used.
