Bridgeport
Old Marine Engine » One and Two Cylinder Gas Inboards » Bridgeport « Previous Next »
Chuck Franklin
Posted on Friday, January 18, 2002 - 03:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for informaiton on Bridgeport engines. Would like to find out the age or approx age of a Model 30 Number 2586A engine.
Chuck Franklin
Richard Day
Posted on Sunday, January 20, 2002 - 05:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I don't know much about Bridgeport engines but I do know that I can throw a little more confusion into the mix. I have seen a U.S. Motors, aka Falcon, ACE OK, Sears Motorgo with the Bridgeport tag and it clearly was original to the engine. I don't know what the relactionship between US Motors and Bridgeport was but there was some sort of marketing arrangement. It would therefore be helpful to see a photo of the Bridgeport.
Posted on Tuesday, January 29, 2002 - 12:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bridgeport did a lot of advertising. They always used the slogon The Motor That Motes.
Here is an ad from a 1912 issue of MotorBoat (the image of the engine is not very clear in the original either).
Regards, Andrew
bridgeport
