Need help , Fox 2 cycle 2cyl
Old Marine Engine » One and Two Cylinder Gas Inboards » Need help , Fox 2 cycle 2cyl « Previous Next »
greg hughes
Posted on Sunday, July 08, 2007 - 09:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any info on fox 2cycle 2 cylinder engine would be greatly appreciated.I need to know what it uses for carburation. Thanks
searcher
Username: searcher
Post Number: 199
Posted on Monday, July 09, 2007 - 12:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Greg,
I assume you are talking about the Fox Reversible Gasoline Engine Co. of Newport, Kentucky. If so, here is a photo of a photogravure of a two cylinder, 2 cycle Fox, from a letterhead dated September 9, 1909.
The carburetor is clearly a Schebler D or one of the Schebler D knockoffs. The air intake adjustment screw seems to be missing but the engraver may have done that deliberately for purposes of overall clarity.
You got lucky on this one. Most of the engine illustrations I need for identifying the carburetor invariably depict the other side of the engine.
keith
Username: keith
Post Number: 183
Posted on Monday, July 09, 2007 - 08:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am attaching a picture of my Fox. I don't know if the carb is correct for the year, but I believe its a Holly.
Fox
greg hughes
Posted on Monday, July 09, 2007 - 10:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for the pictures and the info.I'll try to post a picture,it may take a few days.
