Grease
Old Marine Engine » One and Two Cylinder Gas Inboards » Grease « Previous Next »
mbashaw
Username: mbashaw
Posted on Saturday, May 26, 2012 - 12:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is probably on here somewhere, but what type of grease is best for the grease cups of my Dispro engine?
Post Number: 1497
Posted on Saturday, May 26, 2012 - 09:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Plain old wheel bearing grease available at any auto parts store
Post Number: 629
Posted on Monday, May 28, 2012 - 12:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ernie's suggestion is good if you have the grease cups directly mounted close t the bearings.
But if you have the grease cups out on a dashboard of a boat, connected with 15 - 18 in of 1/4 in copper tubing, then you'd be wise to get thinner grease.
The thick stuff just doesn't move no matter how much you turn the cup.
mbashaw
Username: mbashaw
Posted on Monday, May 28, 2012 - 12:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The grease cups are about 6" off the bearings, and connected by 1/4" copper pipe, so thick is still ok?
Post Number: 1498
Posted on Monday, May 28, 2012 - 01:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Modern wheel bearing grease isn't thick.
Don't use the old stuff that is the consistancy of cold butter. As Miro says it can plug up passages
Yes you can use modern wheel bearing grease with no problems
Hope this helps
