Stuart R3M
Old Marine Engine » One and Two Cylinder Gas Inboards » Stuart R3M « Previous Next »
Ronald E. McClellan
Posted on Sunday, April 20, 2014 - 11:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi guys; I need some help! I have a Stuart R3M. I have run the engine and it smoked up a cloud that you couldn't see through. It apparently sucked the oil out of the transmission into the crank case and burnt it. That means that the seal is bad. I was able to remove the transmission case but haven't been able to remove that 1" long extension that is between the crank case and the transmission case to get at the oil seal. I've removed the bolts and and banged on it to the point that I'm afraid of breaking something. I need someone who has worked on these engines to give me directions. Ron
