Unknown Marine Engine (to me).
Old Marine Engine » One and Two Cylinder Gas Inboards » Unknown Marine Engine (to me). « Previous Next »
denis_rouleau
Username: denis_rouleau
Post Number: 32
Posted on Monday, December 22, 2014 - 11:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can someone identify the builder of this little 2 cylinder engine I recently purchased?
Thanks!
Denis Rouleau
mikeyb
Username: mikeyb
Posted on Tuesday, December 23, 2014 - 06:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like a Dispro D2 to me
(Or is it E2...)
rogerd
Username: rogerd
Post Number: 26
Posted on Tuesday, December 23, 2014 - 06:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
In my opinion I the engine is a Waterman or a close relative. A dispro D2 does not have this type of timer. From what I can see the timer looks like a Meadvile. The D2 had a fractionally larger bore than the Waterman. I don't believe that Dispro ever made an E2.
Post Number: 3423
Posted on Tuesday, December 23, 2014 - 01:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What a nice find !
Waterman / Arrow K2
Denis does your engine have an iron base
or aluminum ?
1920 ad
ar20
Post Number: 982
Posted on Tuesday, December 23, 2014 - 01:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice looking motor, seems complete and original.
denis_rouleau
Post Number: 33
Posted on Wednesday, December 24, 2014 - 11:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I went into the shed, and yes this little Arrow has an aluminum crank case and copper jackets.
These were available in 1920 and I wonder if they were also built in 1919. I can't find much about Arrow after 1921.
Attached is a 1920 Arrow ad.
Denis RouleauArrow K2.
denis_rouleau
Post Number: 34
Posted on Wednesday, December 24, 2014 - 11:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I want to share with you an article from the Power Boating Magazine that tells us more about Mr. Waterman.
Denis Rouleau
Post Number: 3426
Posted on Wednesday, December 24, 2014 - 01:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Earliest Arrow Motor & Machine Co.ad
With inboards is in this issue 1917 on pg 55
mbjan1917
ad did not copy well
Notice this address different than later ads
arrow17
