Need Help with Engine Id
Old Marine Engine » One and Two Cylinder Gas Inboards » Need Help with Engine Id « Previous Next »
tmann
Username: tmann
Post Number: 28
Posted on Friday, December 22, 2017 - 06:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would appreciate any help with information on an engine I just picked up.
It's in pieces with carbs, timer and pump missing.
I've looked for information on it, but about the only one like it I've seen is from a post by Glen K. on 8/15 on Old Marine Engine.
Bores, rods and pistons don't look too bad, so apart from the missing parts listed wouldn't be too hard to get it running again.
Babbitt is still in place, and with a good polishing the crank should be functional.
Any info is appreciated.
The flywheel says Gray Motor Company, with ser#
01014 (only #'s legible)
Thanks,
TMann
