One cylinder marine engine
Old Marine Engine » One and Two Cylinder Gas Inboards » One cylinder marine engine « Previous Next »
Ed
Posted on Wednesday, October 02, 2002 - 11:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I acquired an engine called The Fisherman built by the Universal Motor Co.. Can someone please provide some information on this engine.
Posted on Thursday, October 03, 2002 - 09:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ed,
"THE FISHERMAN" 100% MARINE ENGINE
From the "Universal History":
Quote:
In 19?? the Fisherman (Model WM / WMG / WMGR) 1 cylinder / 67.6 cu in / 8 hp @ 1,200 rpm was introduced. This engine was fitted with a splash lubrication system, and a "Cuno Timer" ignition. The Cuno Timer was an aftermarket contact breaker / condenser ignition module which was fitted by several engine manufacturers instead of magneto ignition. The Fisherman was still listed in the 1940 catalogue.
It is a 4 cycle L-head engine.
I have a 38 page Instruction Book for the engine if you need it.
Regards,
Andrew
