C.l a.e model f10
Old Marine Engine » One and Two Cylinder Gas Inboards » C.l a.e model f10 « Previous Next »
evan_trail
Username: evan_trail
Posted on Saturday, April 15, 2006 - 07:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
any info
Moderator
Username: andrew
Post Number: 637
Posted on Saturday, April 15, 2006 - 01:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Evan,
Nice looking engine. Maybe you could give us some more info about what you are looking for and what you already know... it would save someone doing research to provide what you might already know.
Also use the search link and the top of this page and search CLAE.
Looking forward to some more info from you. Is it your boat and engine?
evan_trail
Posted on Saturday, April 15, 2006 - 07:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hello andrew, this is dads boat and we know nothing about the engine.Yesterday on the water the engine started stalling. The revs would gradually drop,cough,and stall. It started back up straight away but stalled as soon as forward gear was engaged.It made friends with itself after a short time. The engine vibrates and doesnt like to rev. Is
this just the nature of the beast? Anyone have any engine specs/tune/service info. Thanks in advance.
gregoryan
Username: gregoryan
Posted on Thursday, June 08, 2006 - 07:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Wow, they are a lot like the australian Simplex 10-12Hp!! Where are you from? Lovely looking condition! Sounds like it's running too rich on the needle valve or air horn plunger stuck shut from wear, or from the float sinking or from dirt in the float valve.? Does it blow black smoke during this problem?
Dont know about the vibration tho, unless you let it run free/ no load & a fraction more than idle opening may do it?!
evan_trail
Posted on Thursday, June 08, 2006 - 08:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi gregoryan, I am from brisbane but the boat lives at beachmere. I dont remember any exhaust smoke. I will take the boat for a spin and get back to you on this one. And yes the whole boat is in lovley condition.
