Request help to identify a engine
Old Marine Engine » Multi Cylinder Gas Inboards » Request help to identify a engine « Previous Next »
amspicer
Posted on Saturday, September 07, 2002 - 09:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would appreciate any information that would help
identify a boat engine.
The engine is a inline 6cyl.orangey pink in color
with what looks like a transmission bolted to it,
attached to this is a Eaton outdrive. On the block is two sets of #. OH 31 and 8CIDE8015-A
Thanks,
Al Spicer
Posted on Saturday, September 07, 2002 - 11:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Al,
When you say the numbers are "on the block" I would guess you mean "cast" into the block. Is there a nameplate attached to the engine that would have a builder, model number, serial number?
A lot of engines used Eaton outdrives, and the color of the engine doesn't mean much...
A picture might help... but the nameplate data would be best.
Regards,
Andrew
James E. Harris
Posted on Sunday, January 26, 2003 - 05:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Al,
I'm sure you have id'd your engine by now. That second number you quoted is a Ford casting number, so your engine is a Ford.
Jim, the ENGINE ROOM, So. Portland, Maine
Harold Hill
Posted on Wednesday, March 10, 2004 - 09:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1968 Larson,with a 302 Ford and a Eaton outdrive. My question is,does it have an impeller in the outdrive? Because it does have a secondary water pump on the motor.
Harold
david kilgore
Posted on Monday, April 24, 2006 - 06:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Has anyone heard of a Hydrodone boat about a 68
model with a ford engine. Interceptor
larry_from_maryland
Username: larry_from_maryland
Post Number: 152
Posted on Monday, April 24, 2006 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Interceptor is listed in the sparkplug book with several ford engines.It does not say hydrodone.Hydrodone is not listed seperatly.Hydrodyne is listed same as indmar.
Anthony J Zgrodek Jr.
Posted on Sunday, December 30, 2007 - 01:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a small one cylinder outboard that has no tname plate.It's a two cycle w/ egg shaped gas tank wraped around the magneto,pull rope wrapsaround mag & comes off after pulling rope. IT HAS A EISEMANN MAGNETO CORP, Brooklyn , NY w/ Model# 61-M & serial #47-D stamped on bottom of mag. The cast iron cylinder has the # 470-1881 stamped on it's side. The carborater has a cork float W/ Tillotson, Toleto, Ohio stamped on top of fuel bowl & #AJ16A stamped on the side. I need make , year, & horsepower of motor. Appreciate any help.
bruce
Username: bruce
Post Number: 161
Posted on Sunday, December 30, 2007 - 05:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anthony, Try searching on AOMCI.org
Sean Rossi
Posted on Monday, June 23, 2008 - 08:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have an old straight 6 Ford marine engine and need to find out the year and size to get a head gasket. The boat was built in 1973. Please help!
Pat Dunne
Posted on Sunday, April 26, 2009 - 09:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking to find out the value of twin 302 Falcon motors w/ eaton outdrives. They are on an old houseboat I am thinking of buying. They are in excellent condition, and low hours. E-mail me at [email protected]
daveiis
Posted on Saturday, January 23, 2010 - 07:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for help to identify a 215hp v8 interceptor engine the data tag is in bad shape and no help the only numbers i can find are on the timing cover and are as follows interceptor no ce31r523125 any help would be appreciated i'm looking for gaskets valve cover intake timing cover
phil austin
Posted on Saturday, May 05, 2012 - 08:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1963 hydrodyne fish & ski under restoration. Need to identify the eaton outdrive.
I don't know what model it is. This is the info I have, ser.33480 ca 16R26. Saginaw Michigan.
There is a plate on ea side of the outdrive which has a emblem and says Interceptor 165. The engine is a Ford 260 Interceptor. Need to remove the outdrive and replace the bellows and possible seals? Any help in directions for removing and locating parts will be appericated.
thank you
