Crosley marine engine
Old Marine Engine » Multi Cylinder Gas Inboards » Crosley marine engine « Previous Next »
dankruitz
Username: dankruitz
Post Number: 9
Posted on Friday, May 19, 2006 - 07:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just acquired a Crosley marine engine complete with all the goodies (4-cylinder inline overhead cam, 44cu in.) The whole thing fits nicely in my car trunk.
I was hoping to ID the year, the serial# is
115230C. Also, does anyone know what model of Zenith carb it is (looking for carb kit too). The transmission is made by Snow-Nabsted out of Hamden, Conn. -- never heard of that make before. It looks to have a gear reduction unit on it too.
Just took a quick look under the cam cover, and the cam looks decent at first peek. I'm an antique outboard collector, so this is new
territory for me - four stroke, valves and a cam - oh, my! :-) I just figured out the little "thingy" on the cam cover is an attachment point for a mechanical tachometer which drives directly off the cam shaft.
Of course, I'm looking for any newbie tips you can offer. I'm hoping to get the motor running, then build a Class-Z/Class-48 runabout racer around it.
Thanks,
Dan
doncustis
Username: doncustis
Posted on Sunday, May 21, 2006 - 01:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Crosley pump engine and it has a Carter model (W-O) and a parts house gave me a kit for a late 40's or early 50's jeep carb and it worked, D Custis
doncustis
Username: doncustis
Post Number: 7
Posted on Sunday, May 21, 2006 - 01:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try The Crosley Parts and Service People, at P.O. Box 116 or 8111 ST. Rd. 16 East Twelve Mile, IN. 46988 1-219-664-3313 or 1-219-722-1152
Post Number: 126
Posted on Sunday, May 21, 2006 - 12:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
As an outboard collector you should be familiar with the Homelite 4 stroke outboards, they used a vertical version of this engine. These are high revving engines and a reduction would seem fitting. S-N gears were used on the early Palmer Baby Husky, same era as the Crosley.
