Chrysler Ace Marine engine manual
Old Marine Engine » Multi Cylinder Gas Inboards » Chrysler Ace Marine engine manual « Previous Next »
Gord Gowie
Posted on Thursday, May 17, 2007 - 04:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone help me find a manual for a Chysler Ace marine engine vintage approx 1947.
Robert Bricker
Posted on Monday, May 26, 2008 - 03:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Give Gilbert Plumb in CT a try. He is copying a M-6 service manual for me now. That is from around the same time, he also said he had other manuals too.
He can be reached at (860)767-7351
ptorchio
Username: ptorchio
Posted on Monday, June 16, 2008 - 09:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1946 Ace M6 in a Gar Wood Ensign and the operating instruction manual for it. Is there a more detailed manual? I would really like a shop repair manual if one exists. I would be glad to make copies of the operating manual if it would help anyone.
PT
Pat Renaud
Posted on Sunday, September 16, 2012 - 05:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am rebuilding a revers/reduction gearbox for an old Ace that a customer had dropped off in boxes. The needle bearings are missing from the reverse gears. Does anyone have a spec/part number for these, or a set that I can buy? Timken Bearing says they can supply them if I can give them specs. Thanks.
ptorchio
Username: ptorchio
Posted on Monday, September 17, 2012 - 08:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you can mike the bearing housing and shaft I would think a good bearing shop could cross reference the bearing. I would be surprised if the bearing was a needle bearing though considering the age of the gear box.
