Cracked Water Shield on 350 inboard
Old Marine Engine » Multi Cylinder Gas Inboards » Cracked Water Shield on 350 inboard « Previous Next »
Michael Adams
Posted on Tuesday, March 23, 2004 - 03:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a cracked water shield on a 350 marine engine.the crack is about 3 inches long. i believe is a freeze crack. Would JB Weld do the trick or do i need to do something else? Thanks!
Jim
Posted on Tuesday, March 23, 2004 - 10:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can try te JB Weld but I dont think it will work. Is the water shield like the water jacket in the block and if so the crack can go in further allowing water to go anywhere in the engine causing damage to moving parts.
Michael Adams
Posted on Tuesday, March 23, 2004 - 10:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What would you recommend?
bill schaller
Posted on Wednesday, March 24, 2004 - 07:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
do a google search for metal stitching
Posted on Wednesday, March 24, 2004 - 08:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
one that I have used is:
Lock'n'Stitch
