Chrysler 318 Antifreeze leak
Old Marine Engine » Multi Cylinder Gas Inboards » Chrysler 318 Antifreeze leak « Previous Next »
dnasamg
Username: dnasamg
Posted on Sunday, July 17, 2005 - 08:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have antifreeze dripping from the bottom of my 318 marine engine. It seems to be dripping off the bottom of the oil pan toward the transmition. I can not get down there to see were it is coming from--any ideas where it may be leaking from- There is no antifreeze in the oil- motor is not smoking- motor seems to run fine.
RonMcInnis
Posted on Sunday, February 26, 2006 - 09:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello, just went through this one myself. There are 2 frostplugs located inside the bellhouseing, on the block. They tend to get rusty, and leak.
You will have to remove the transmission, and bellhousing, and flywheel to get to the problem.
