318 chrysler ffywheel
Old Marine Engine » Multi Cylinder Gas Inboards » 318 chrysler ffywheel « Previous Next »
Redbear
Posted on Monday, May 29, 2006 - 07:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 318 chrys. marine.have a velvet drive bellhousing and a rear mount srarter.I am useing a 12in. flywheel,mopar 318-400-440.the starter misses the flywheel by about 1/4 of an inch.does this set up use a larger flywheel or ringear.It starts fine with a truck bellhouseing and
starter. Thanks RED
Moderator
Username: andrew
Post Number: 666
Posted on Sunday, June 04, 2006 - 12:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Redbear,
You might be better off asking that question in the Chrysler category of MarineEngine.com
Your engine might be old... but it isn't really old enough.
Most of the marine engine discussed and covered on this site are pre-1940 style slow speed inboards.
