Motor oil choice
Old Marine Engine » Diesel Inboards » Motor oil choice « Previous Next »
GLowell
Posted on Saturday, November 17, 2001 - 08:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Volvo MD1 that is running fine. Other boat owners I have spoken with suggest I use a new synthetic oil (Mobil 1) to help improve lubrication at start up. It sounds like a good idea but on the other hand it has been running fine for 35 years with good old 30 weight. Any thoughts on this?
Maxime Hamel
Posted on Sunday, August 18, 2002 - 04:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I recommend adding Lucas oil additive.It has stopped an oil leak in my 92 Volvo car. Also I use it in my boat which has twin Palmer Marine
Diesel D301 and have increased my oil pressure
by 5lb. Most auto part stores carry it. It really
works.
poker casino669
Posted on Monday, March 06, 2006 - 04:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 273
olevolvo
Username: olevolvo
Posted on Sunday, April 08, 2007 - 01:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am to intall an MD1B, 10hp volvo penta 1970 model. What do you think is the best oil to use
eddie
Username: eddie
Post Number: 168
Posted on Sunday, April 08, 2007 - 01:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Make sure that the oil is rated for use in a diesel engine. Oil rated for gasoline engines only is not suitable for use in diesel engines. It will be noted on the container. Other than that, use the viscosity rating recommended by the manufacturer. I would think that 10W-40 or 15W-40 would be good. The key to engine longevity is keeping the oil and oil filter changed regularly.
