Volvo Penta MD1 Wiring Diagram
Old Marine Engine » Diesel Inboards » Volvo Penta MD1 Wiring Diagram « Previous Next »
boomer
Username: boomer
Posted on Monday, January 28, 2008 - 01:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all
Im looking for a wiring diagram for a volvo penta MD1 with a dyno start.
I see a previous post here being a novice Im not too sure I'll interpret it correctly. Im more of a visual learner (i.e. pictures) than a read and comprehend type :-)
Any help greatfuly recieved
adsum
Username: adsum
Posted on Monday, January 28, 2008 - 02:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
There is a wiring diagram in the manual of MD1B that is available in PDF-format at:
http://www.volvo.com/volvopenta/global/en-gb/marine_leisure_engines/parts_servic e/publication_search/publication_search.htm
boomer
Username: boomer
Posted on Tuesday, January 29, 2008 - 05:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
that exactly what I needed.
Thank you
Eugenio
Posted on Thursday, July 31, 2008 - 05:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all,
does anyone have a Volvo Penta MD1b engine for sale? Maybe in Europe?
Thank you
Eugenio
tbower21
Posted on Friday, July 15, 2011 - 01:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi there,
I am looking for the electrical drawings/schematics on the Volvo Penta D6-310A-B.
eric
Username: eric
Post Number: 23
Posted on Sunday, October 13, 2013 - 06:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any one got a regulator for a Bosch dynastart on an MD1? with wiring diagram if possible..
nobby
Username: nobby
Post Number: 34
Posted on Tuesday, October 15, 2013 - 10:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your best bet would be to put together a separate regulator and solenoid combination. I would recommend the following regulator and their data sheet has a wiring diagram:
http://www.dynamoregulators.com/dvr2-s.php
Solenoid - Wire that was going to 50 on original regulator now goes to one side of the new solenoid coil the other side of the coil goes to ground. The wire that was going to B+/30 (Main Positive Supply) on the original regulator now goes to one side of the switched contacts the other side of the switched contacts goes to 30 on the dynastart.
Regulator Brown - Ground
Regulator Yellow - DF on Dynastart
Regulator Blue - D+ on Dynastart and indicator Light
Regulator Red - +ve supply attach this to what was B+/30 positive supply to the solenoid contacts.
D- on dynastart is common to the casing and is ground this sometimes used to supply negative to the regulator negative terminal 31 and hence if you wish can be how the new regulator brown wire gets its ground.
Cheers
Nobby
