Perkins single cyl. diesel
Old Marine Engine » Diesel Inboards » Perkins single cyl. diesel « Previous Next »
gonefishing
Username: gonefishing
Posted on Thursday, March 31, 2016 - 02:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
G,day all,l have a pair of perkins single cyl. diesels, one is stationary & the other is marine with it's gear box, my question is can anyone shed some light on the age,hp,availability of parts etc. or any other info. these engines have lD. plates showing "perkins 1.36m made in Germany" no s/n's also the gearbox has the no,s 30/40 embossed on the housing, both engines are green. Cheers Jim.
nobby
Username: nobby
Post Number: 60
Posted on Thursday, April 07, 2016 - 08:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I believe that they are actually Farymanns. I suspect that what you have is an A30.
Download the following and see if it is a match?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj6t6G Q4P3LAhXFyRQKHfARDzQQFggeMAA&url=http%3A%2F%2Fwww.capedory.org%2Fmanuals%2FFarym annDiesel_A30M-A40M-K30M-R30M-P30M-S30M_InstManual.pdf&usg=AFQjCNFq9uGp6yLVb1WwI EDZRFFyjsB2Mw&sig2=aZMjheXZj6O7hNEfR_23sw
Cheers
Nobby
gonefishing
Posted on Sunday, April 10, 2016 - 09:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
G,day Nobby, thanks for your response to my question, re. farymann a30, l believe it came out of a timber ex life saving boat built in the 1930,s, 22 ft. made of New Zealand kauri which l purchased 2 yrs.ago, also thanks for the info re. these engines. One quest! can one still get parts for these? Cheers Jim
nobby
Username: nobby
Post Number: 61
Posted on Monday, April 11, 2016 - 09:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Perkins will no doubt be of little help to you. Were I you I'd contact Farymann and see what they have to say about it as this will be most likely your only hope for parts.
Cheers
Nobby
gonefishing
Posted on Monday, April 11, 2016 - 08:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Cheers Nobby for your last response, you have been most helpful,Jim
