YANMAR OIL PRESSURE
Old Marine Engine » Diesel Inboards » YANMAR OIL PRESSURE « Previous Next »
baboo
Username: baboo
Posted on Thursday, September 16, 2004 - 05:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my yanmar yse 12 starts with a pressure of 24 psi but drops to 7 psi when warmed up is this normal?
eddie
Username: eddie
Post Number: 19
Posted on Thursday, September 16, 2004 - 09:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
baboo,
Most engines run at 30-35 warm and higher when cold. Generally older engines have less pressure as the bearings wear. What viscosity of oil are you using?
Eddie
Paul Kenney
Posted on Sunday, May 08, 2005 - 01:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My 12 horse 1 cylinder Yanmar (circa 1980) engine has run way on two occasions,once in the beginning of the season and once at the end last year. I would like to avoid this horrorfying experience again. Any tips on what causes the problem and how to avoid it?
