Propshaft removal
Old Marine Engine » Site Announcements and Information » Propshaft removal « Previous Next »
nick baranet
Posted on Monday, August 30, 2004 - 02:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
craft is a 1962 Vietnam era PT boat. We are trying to remove the circular "brass" seal that holds the rubber cutlass bearing???, in place that the propshaft actually rides on. Does anyone know if it is screwed on (our 1st thought) No luck. Pressed on??? Heat,a chain wrench ect no go. Any ideas would be appreciated. Nick
Post Number: 541
Posted on Monday, August 30, 2004 - 05:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
One of the best solutions i've heard is to remove the prop shaft, spray the bearing area with Pb blaster, wait a little while and then call the yard mechanic to do the job !
If you want to tackle it yourself ?
http://www.catalina30.com/TechLib/Cutlass%20Bearing/cutlassbearing.htm
Moderator
Username: andrew
Post Number: 871
Posted on Monday, August 30, 2004 - 07:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nick,
Who manufactured the Cutlass bearing? They should have a drawing that will show how the retaining ring is attached...
I would think it should be hex head bolts into blind threaded holes, then the heads of the bolts would be wired together to prevent them backing out.
bruce
Username: bruce
Post Number: 214
Posted on Monday, August 30, 2004 - 09:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I bet there's a navy/dod manual on it...
poker casino407
Posted on Monday, March 06, 2006 - 07:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 995
Richard Oylab
Posted on Tuesday, July 11, 2006 - 11:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1948-50 2 1/2 horse Johnson Seahorse. It runs great for about 45 min. and then stalls out. It can be restarted, with priming, but will only run for about a minute. Any ideas what the problem is?
clayton orchek
Username: offhandglass
Posted on Wednesday, October 10, 2007 - 12:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
need help on Palmer 9(?) HP motor, i can not turn it over by hand, turns a few degerees, then clunks. The propellor will not turn it either, it may be in gear but do not know how to disengage, there is a bronze d-grip that slides up and down, previous owner said it was to shift tranny. has not run in 15 years or so. should i pull it out of the boat to work on it or is there a way to determine the nature of "stuckness" easier, ie, pull the cylinder up? i would love to get this running, its in an old sailboat and would be great rather than a nasty new outboard-THanks- clayton
Post Number: 521
Posted on Thursday, October 11, 2007 - 08:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Clayton, Don't pull the cylinder. Yet. typically there is a flange coupling between the engine/reverse gear and the propellor drive shaft. I suggest you remove the bolts that hold the two flanges together. Mark the flanges befor you separate with a sharpie them so you can bolt them back together with the same relative position they have had for many years. Then you should be able to rotate the prop and the engine separately and quickly determine which has the problem. Can you send a picture of the engine so I can help you determine what model Palmer you have. If no picture can you describe the engine??
