Max Pic size
Old Marine Engine » Site Announcements and Information » Max Pic size « Previous Next »
Post Number: 2590
Posted on Friday, May 01, 2020 - 10:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
All,
The maximum pic size that can be posted on the OME Discussion Board is 200K. It got bumped from 100K to 200K about a year ago.
As always if anyone has difficulty resizing pics send them direct to my e-mail and I will resize them and post for you. Please do NOT send me 10 or 20 pics as I won't be able to get them done in a timely manner.
Also there is a Picture resizer here on OME. Use the link below to go to it. I just resized a 6.5 meg pic using the 600 resizer and it came out to about 55K
http://www.oldmarineengine.com/resize/resize.html
To use it select the 600 pixel resizer (the bottom one) click browse and select the pic you want to resize from your PC or local drive. Then click resize. This might take a bit. Once the pic is resized right click on it and save it back to your PC. I would suggest creating a folder on your desktop to save these in so they are easy to find.
Now you can select resized pic from your desktop and upload it to OME as part of your post.
Note it is suggested that you hit the enter key after EVERY uploaded pic so they will all be at the left margin.
Hope this helps.
Post Number: 2591
Posted on Friday, May 01, 2020 - 11:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
More info here
http://www.oldmarineengine.com/discus/messages/3425/9663.html
Note this post is 15 years old however it is still valid information. As stated make sure to hit the enter key after every pic upload. Hitting it twice is even better as there will be a seperation between your pics which will all be at the left margin.
