Sherwood E20 water pump
Old Marine Engine » Palmer Engine Co » Sherwood E20 water pump « Previous Next »
Dean Paul
Username: mdlife
Post Number: 7
Posted on Saturday, October 08, 2011 - 10:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you have a Palmer P60 you most likely have a Sherwood E20 water pump. I needed to rebuild my E20 pump due to seals leaking but could not find the replacements shaft...so I had some made out of 316 stainless steel. If you need a shaft I have an extra..will not be cheap due to the fabrication costs to make. You simply cannot get these shafts anywhere..I tried. Call me if interested...Dean 414-588-6464
David Grosse
Username: davidg
Post Number: 18
Posted on Monday, June 02, 2014 - 12:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Dean,
Do you still have the extra shaft? Could you have some more fabricated? I am interested and could use 5 to 10 of them depending on cost factors.
Thanks,
David
