Palmer PW-27 slow warmup
Old Marine Engine » Palmer Engine Co » Palmer PW-27 slow warmup « Previous Next »
Jeff Hall
Posted on Tuesday, March 18, 2008 - 01:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a PW-27 engine in my sailboat. It runs good but takes 20 or 30 minutes to warm up and take a load without stalling. Even when fully warmed up the head is fairly cool to the touch. It is raw (salt)water cooled and has no provision for a thermostat. Any suggestions appeciated.
Roger DiRuscio
Username: solarrog
Post Number: 292
Posted on Tuesday, March 18, 2008 - 02:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
adjust the carburetor its running lean
Post Number: 571
Posted on Tuesday, March 18, 2008 - 06:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Don't think you can raise the engine temp over 143F with salt water cooling. All you will do is fill the water jacket with a solid block of salt and totally destroy the engine. I agree the needle valve needs to be opened slightly.
Jeff Hall
Username: jeff_hall
Posted on Thursday, March 20, 2008 - 01:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Which needle valve,the"idling needle valve" or the"main jet adjustment"? I'm glad I didn't restrict the water flow like I was thinking of doing. Thanks for your answers.
Post Number: 572
Posted on Thursday, March 20, 2008 - 04:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The main jet adjustment. If that doesn't work suspect the inlet to the top of the float valve may be full of junk limiting full fuel flow. The only easy way to clean it out is to remove the fuel line fitting and used compessed air with a soda straw or equivelent. Push the straw into the bottom of the opening and blow the junk out alongside the straw. They make nifty sets of tips for compressed air blow guns that perform this function very well. Blowing in without the straw or equivelent doesn't drive the gunk out it too often tends to force it into the valve seat
