Two barrel intake manifold that would...
Old Marine Engine » Palmer Engine Co » Two barrel intake manifold that would connect to an IHC 152 « Previous Next »
Andrew Menkart
Moderator
Username: andrew
Post Number: 1325
Posted on Wednesday, January 11, 2006 - 12:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The following question came in by email, maybe someone can help...
quote:
hello my name is john and i'm a bit of an IHC nut.
i have been told that palmer made a two barrel intake manifold that would connect to an IHC 152 cid 4cyl motor and was designed for a weber DG model progressive 2bbl carb. these carbs were used on pintos, vegas, chrysler 2.2 and 2.5 and various others.
i'm building a IHC Scout 80 that currently has a
152 4cyl in it and may get a 196 4cyl transplanted into it later. then factory IHC manifold for the 152 will fit and work on the 196, and i'm hoping that i could find the palmer marine manifold to use on my Scout.
any info to aid in my quest would be most helpful and greatly appreciated.
thank you
john carr
918-697-5830
[email protected]
