OXB Transmission
Old Marine Engine » Palmer Engine Co » OXB Transmission « Previous Next »
David Offenstein
Username: daveo
Post Number: 7
Posted on Monday, May 19, 2014 - 08:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI, When pulling into the dock in forward gear, the shift lever was like frozen in place, I had to pull really hard to get it out of gear. Really hard! After I removed the shift cable which was almost frozen, I lubed it and now it works fine. I re-installed the cable, however now I don't have reverse, and the shift lever feels real funny when I move it, it seems to have very little resistance. Almost too smooth. I checked the positioning of the cable to the transmission lever, it is correct. I turned the engine over by hand, and forward, neutral, reverse is all there, but not under power, I have forward, neutral seems hard to find, and no reverse. Before I take the cover off the transmission, I was wondering what your thoughts are, what I should be looking for. Why it was stuck in forward gear in the first place, I feel that the shift cable, how ever bad, is really not the problem. Maybe a contributor, but not really the issue. Thanks for any advice you can give me. I love my Palmer, and the OXB. This is a direct drive.
Post Number: 924
Posted on Tuesday, May 20, 2014 - 08:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Forward locks the clutches, reverse applies the band. Usually you can adjust both, remove the cover and look for an adjustment screw on the band, try taking up some slack.
