Pw-27 question
Old Marine Engine » Palmer Engine Co » Pw-27 question « Previous Next »
Bryan Flanigan
Posted on Sunday, April 08, 2012 - 12:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am rebuilding a pw-27. I bought a manual as well as a book on single cylinder gas engines. So far everything is going as planned. However I have run into one thing I can't figure out.
In the side of the valve chamber there is a right angle flare fitting. what does this connect to? In the manual I found a few pics that showed the fitting, but only one that showed a line running from it, but I can't see where it goes.
Any ideas?second flare fitting from top on right side
Steve Francis
Username: sfrancis36
Post Number: 8
Posted on Sunday, April 08, 2012 - 02:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I believe that's the crank case vent to the caburator. It is on mine.
Steve
Post Number: 1483
Posted on Sunday, April 08, 2012 - 08:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yup it is the breather
It is just a short piece of copper tubing ending in front of the carb air inlet flame trap
bryan Flanigan
Posted on Sunday, April 08, 2012 - 03:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No wonder why I can't find where it goes, it goes nowhere!
Thanks for the help. So that recycles the gases that slip by into the crankcase and reburns them right?
Post Number: 1484
Posted on Sunday, April 08, 2012 - 06:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Yup that is exactly what it does. The end is cut at a 45 so it goes kind of flat against the front of the flame trap
