Starter/Generator Schematic
Old Marine Engine » Palmer Engine Co » Starter/Generator Schematic « Previous Next »
Howard Argales Sinclair Jr.
Username: vahowdy
Post Number: 7
Posted on Sunday, July 19, 2015 - 11:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is the electrial drawing for my PW_27 in my boat. I hope this could be of help to some of you. It would work for any Delco Starter/Generator system with a magneto.Electrical drawing
David Grosse
Username: davidg
Post Number: 41
Posted on Wednesday, July 22, 2015 - 08:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Howard,
Thanks for posting the diagram. It may help me with my Atomic 2 project. That engine came to me without any wiring, but has a magneto and a starter/generator.
Regards,
David Grosse
David's Yacht Service
SoCal
Username: vahowdy
Post Number: 8
Posted on Thursday, July 23, 2015 - 08:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi David, I see, I did not show the voltage regulator case grounded.
Norman Narmore
Username: normann
Post Number: 10
Posted on Sunday, September 18, 2016 - 09:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Howard, Thanks for sharing this drawing, I love it! I'm in the process of getting my PW-27 running and tested before it goes into the boat. It never occurred to me to use an ignition switch as a ground. A simple solution if there is no problem with everything half way hot all the time. Sorta similar to a positive ground system I guess.
Can you or anyone else give me the Voltage Regulator Model Number for the correct Delco/Remy starter/generator used on the PW-27? I looked in the archives but could not pin it down. Thanks!
