P60 head bolt tightening sequence
Old Marine Engine » Palmer Engine Co » P60 head bolt tightening sequence « Previous Next »
David Blakey
Username: catboater
Post Number: 11
Posted on Monday, October 20, 2008 - 02:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm re-installing my cylinder head on my P60. I've got the bolt tightening sequence from an old thread, but have a question. Are the No. 10-11-12 bolts on the flywheel end or the transmission end of the engine?
Eddie Ross
Username: eddie
Post Number: 222
Posted on Monday, October 20, 2008 - 06:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That would be at the transmission end which is also the end that has the water outlet fitting.
David Blakey
Username: catboater
Post Number: 12
Posted on Tuesday, October 21, 2008 - 12:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks, Eddie. That's what I would have guessed, but I wanted to make sure. Guess I'll eventually have to break down and buy the manual!
