1965? AMC Gray Marine
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » 1965? AMC Gray Marine « Previous Next »
Mike O'Brien
Username: mmob1comcastnet
Posted on Saturday, June 22, 2013 - 11:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
150Hp is it a a 252 or 232 Rambler or Valiant motor and what is the correct spark plug gap...Thanks Mike
Post Number: 1690
Posted on Saturday, June 22, 2013 - 07:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If it points ignition .030 in should work well
Solid state ignition you can go to .040 in
