6-140
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » 6-140 « Previous Next »
Martin
Username: martanke
Posted on Wednesday, September 14, 2011 - 08:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
In the Engine serial number identification list posted by Jim Staib at http://www.finewoodboats.com/Gray.htm, there is a 6-140 engine listed under G7700-7899 and H12400-12499.
Is this the dual carb 6 cyl Fireball or could it be some other engine?
Jim Staib
Username: drrot
Post Number: 100
Posted on Thursday, September 15, 2011 - 07:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Most likely the same engine but different years. 2carb 6cyl
Larry Smith
Username: longhornlarry
Posted on Friday, July 28, 2017 - 07:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What was original carb on a 1946 Century deluxe runabout, Phantom 4-75
Any other specs on engine and tranny helpful.
Larry S
Jim Staib
Username: drrot
Post Number: 228
Posted on Sunday, July 30, 2017 - 09:46 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
10296 is what the manual says
