Head gasket, Sea Scout
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Head gasket, Sea Scout « Previous Next »
John Doran
Posted on Wednesday, May 04, 2005 - 08:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am looking for a head gasket for a Gray Marine Sea Scout 4-91. Are any available ....anywhere?
pcwroble
Username: pcwroble
Posted on Tuesday, May 10, 2005 - 11:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm in the process of purchasing a head gasket for my Gray Marine Sea Scout 91 from Custom Marine & Machine Services @ http://www.customclassicmarine.com/
They are also checking the head for warping as that is usually the reason for a head gasket to blow or is caused when one does blow. If it is warped and isn't reconditioned, the gasket will blow again. They can re-surface the head if it is warped. They can also replace any part for it.
