Straublel mixers
Old Marine Engine » Carburetors, Mixers, Vaporizors » Straublel mixers « Previous Next »
Richard Alcock
Username: raa
Post Number: 19
Posted on Friday, June 11, 2010 - 09:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have a Strauble twin with the original mixer running? I am working on a 10 hp twin with the Straubel mixers which appear to have never been messed with and have a lot of questions. How well do they work and how are they adjusted? They appear to have a poppet valve which is seated with a light spring which is adjustable with a dial. As the poppet valve lifts up it opens a course needle valve allowing gas to puddle on the tip of a brass stem. The air flow is adjustable with a shutter like device. What is the vertical round stud with four flat surfaces shaped much like a soldering iron? Straubel engine as foundStraubel mixermixer partly apart
William Schaller
Post Number: 333
Posted on Friday, June 11, 2010 - 11:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey, if you want, I will trade you a pair of Scheblers for them. let me know, I would even pay postage both ways.
Brock Frank lee Mahaffy
Username: brock
Posted on Friday, July 24, 2015 - 12:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Do you guy know if any of you got a
Spare staubel carburetor mixer? For the museum I work at as an old Straubel engine and I'm only 13 years of age if so here's a number to contact 9062419610
Username: brock
Posted on Sunday, July 26, 2015 - 05:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a dual carburetor strauble mixer I will trade you for a single straubel carburetor mixer.
Dick Alcock
Posted on Wednesday, July 29, 2015 - 09:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I decided to post a couple of pictures of my completed Straubel 10 hp. Turns out the mixers work great. I did notice the needles became rather sensitive as the gas got low in the tank. As usual JB had the answer and sent me a period after marked float assembly which solved the problem, keeping the gas pressure constant on the needles. I got busy and made a pattern and core box and had a float bowl cast. I used a modernTecumseh float . The float bowl shows in on of the pictures behind the flywheel. This engine restore turned out out to be a long one. It took 4 years and 4 foundries before I was able to get a good exhaust manifold. Can Do Metal in St Ann Ill finally figured out that if you mould the pattern vertical and gate at the bottom the inrush of hot iron would not break the cooling jacket core which is only 1/4" thick. These are easy starting and easy to reverse engines.
StraubelStraubel
Post Number: 3627
Posted on Wednesday, July 29, 2015 - 09:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick
I am always amazed with your excellent work !
That is a beautiful old marine engine !
Post Number: 1082
Posted on Wednesday, July 29, 2015 - 10:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks great Dick, I'm working on a project now that may need the vertical pouring trick, glad you found someone to solve the problem.
Dick Alcock
Posted on Wednesday, July 29, 2015 - 11:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is the amount of fiddling about to make the pattern and core boxes for the exhaust manifoldStraubel
