Kermath Sea Pup Transmission
Old Marine Engine » Kermath » Kermath Sea Pup Transmission « Previous Next »
Michael Keane
Username: walkintee
Posted on Tuesday, July 17, 2007 - 03:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1972 5 hp Kermath Sea Pup gas engine in my sailboat that is blowing oil out of the transmission breather tube located at the back top of the transmission when the trannie is in gear... Anyone know why or how to fix it? Anyone know anyone who does this kind of work near Brooklyn NY? Or any used trannies for sale or any new ones that are adaptable?
Thanks,
Michael Keane
[email protected]
Joe Holmes
Username: joe_h
Post Number: 12
Posted on Saturday, July 21, 2007 - 02:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Mike...I have a Sea Pup which is slowly coming together and had a look at my transmission which is off the engine. The transmission and the engine share the same oil so there is no dip stick or oil filler hole in the transmission and therefor no need for a breather. Plug it. If your tranny has separate oil then you probably need a breather which doubles as a fill hole. If this is the case then if oil comes out when you put it in gear you simply have too much oil in the tranny
Raymond Prophet
Username: raymo9
Posted on Friday, June 13, 2008 - 07:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi--I have a Kermath seapup transmission for sale. You can have the transmission for $150 or the whole engine for $400. Let me know.---Ray
Richard Brown
Username: richbrown
Posted on Friday, September 23, 2011 - 09:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
do you still have this engine and trans?
