Stuart Carb or ?
Old Marine Engine » Stuart Turner » Stuart Carb or ? « Previous Next »
Mathijs Vorstman
Username: devorst
Posted on Monday, April 13, 2009 - 10:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My R3M has a Stuart carburettor ( I think) and it is build in a little launch (4m)
But it looks different from all the pics I have seen so far.
The float chamber looks different. See attachment.
Could someone tell me if it is a Stuart carb or something else?
I also have some difficulties adjusting it: air / fuel mix.
The mixture is to rich. The jet is a 34. Any tips?
And last: I think I need a new needle. Does anybody know where to get one?
It would be great if somebody can give me some info.
Stuart Carb ??
parts stuart carb
Mike Hodgson
Username: orwot
Post Number: 49
Posted on Monday, April 13, 2009 - 04:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would say it is a Stuart carb altho not one I have come across before.The plastic float is fairly modern and the hinge pin in the photo seems to be bent.This could cause the float to stick and give you a rich mixture.Before trying to locate a needle sort out the float operation.Afraid cannot help with a source for a new needle.You could try lapping it in gently with metal polish .
Peter Ogborne
Username: peterogborne
Post Number: 293
Posted on Monday, April 13, 2009 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Definately a Stuart Carb ....looks like it has seen better days .However it should be quite OK .Just put it back together with care .Wind in the air control until there is a gap of about 6mm .....this is a good starting point for adjustment.
New needle ,either make one or as Mike said lapp in the original.
Mathijs Vorstman
Username: devorst
Post Number: 7
Posted on Tuesday, April 14, 2009 - 03:48 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thaks for the info guys.
About the air: A gap of 6mm: how is that? 6mm from where to where?
Peter Ogborne
Post Number: 294
Posted on Tuesday, April 14, 2009 - 05:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mathijs, I am emailing a descriptive image to you
Hugo Derrick
Username: hello
Post Number: 11
Posted on Thursday, April 16, 2009 - 03:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello Mathijs -
The carburretor
you have there is what Stuart called the 'Stuart 1972' carb; I have one on a late R3MC; as with all Stuart carbs, fed with clean fuel (be sure to clean the filter in he banjo annually) they work very well.
Regards,
H.
kev percival
Username: kebalush
Posted on Saturday, May 16, 2009 - 06:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
to mathijs vorstman your float pin might be the same type as they use on vespa scooters the models are known as the small frames and the pk and pk xl models.as looking at your picture of the plastic float they look very much the same.on these vespas they use the same type of set up and the models are as follows ie what country are you from if in amercia or europe you will have no problem getting on from a vespa or piaggio dealer here is the models that use this type of pin worth a try price would be around 1.00 to 2.00 pounds.
vespa 50
vespa 50 special
vespa v.90
vespa v.100
vespa pv-125
vespa pv-125 et3
vespa pk and pk xl models in 50 80 100 125.
hope this may be some help to you all the best kev.ps may be a lambretta series 3 carburettor float pin on the series 3 all the models ie li sx tv gp italian spanish and indian models all use the same type pin hope one of these helps you out many thanks
Mathijs Vorstman
Username: devorst
Post Number: 8
Posted on Sunday, August 09, 2009 - 06:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
My Stuart Carb still has a way to rich fuel mix.
In spite of all your tips and help (thanks for that though) I still can't find the solution . The needles suggested are to long or to thin.
So I if anyone knows where I can get a new needle please let me know.
Does anyone know if the 34 jet is the correct one for my carb?
I notice that if I turn off the fuel, my engine runs perfect just before it runs out of fuel.
As I see it it can only be the needle that doesn't completely closes of the fuel supply or the jet is to big.
I have straightened the hinge pin.
Thanks, Mathijs
