P55ME speed changes and throttle make...
Old Marine Engine » Stuart Turner » P55ME speed changes and throttle makes no difference « Previous Next »
Anthony Hall
Username: burgundyman
Posted on Tuesday, September 01, 2015 - 06:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am a new owner of a 19 foot river boat with a P55ME in good condition. I am using 50:1 premium unleaded fuel with a 2 stroke outboard motor oil (valvoline). When we start the engine it runs powerfully for about half an hour and then halves in speed and depending on mood runs at either full or half pace. When this happens the throttle seems to make no difference. Does anyone on this board have a suggestion as to where I start to solve this issue ?
Roger DiRuscio
Username: solarrog
Post Number: 597
Posted on Tuesday, September 01, 2015 - 11:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try something simple first. Check the fuel tank gas cap vent hole, If the vent is plugged the engine will starve but struggle to run
Anthony Hall
Posted on Thursday, September 03, 2015 - 10:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dear Roger,
Thank you for the suggestion. I did unscrew the fuel cap while the engine was in it's low revving mood but it did not make a difference. I will double check the vent hole regardless.
thanks again
Anthony Hall.
Roger DiRuscio
Username: solarrog
Post Number: 598
Posted on Friday, September 04, 2015 - 12:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Next check the fuel filters
Keith Inglis
Username: oslin04
Post Number: 86
Posted on Wednesday, September 09, 2015 - 08:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
When I used to work on with those engines installed the biggest trouble we had was crankshaft seals letting air in to the crankcase, might be worth a check,
Keith
