Information exchange
Old Marine Engine » Stuart Turner » Information exchange « Previous Next »
Mike Hodgson
Username: orwot
Post Number: 31
Posted on Sunday, July 13, 2008 - 02:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
5 files now uploaded including R2/R3 handbook ,P55 coil ignition.More soon.
http://groups.yahoo.com/group/stinfoexchange
Nicholas Tracy
Posted on Tuesday, September 20, 2011 - 04:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am having difficulty removing the gear shifter of my Stuart Turner P5MR. The manual says to remove the four hold down bolts but not to touch the centering pin. Having done so, the shifter mount is loose, but will not lift out. Is there something I am missing?
Miah Gregory
Username: mace
Post Number: 16
Posted on Tuesday, September 20, 2011 - 07:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The centering pin has to also be removed. I believe the manual is really talking about the brass inset which the centering pin goes through - don't move that if you can help it.
