P55 ind more help please
Old Marine Engine » Stuart Turner » P55 ind more help please « Previous Next »
dondom
Username: dondom
Post Number: 8
Posted on Monday, June 06, 2005 - 05:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks for all the help so far i have now got the engine running but i think i it is the wrong plugs and the solex carb is flooding badly.So can anyone help with set up instructions for the carb and tell me what plugs i should be using
mike_sutcliffe
Username: mike_sutcliffe
Post Number: 9
Posted on Monday, June 06, 2005 - 06:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have found that Champion L86C plugs work OK. I have not tried them but the Lodge C14 is an equivilent. The original Champion L14 is no longer available.
David Stott
Posted on Monday, June 06, 2005 - 10:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I also run a solex carb on my P55 and experienced flooding problems. There is no adjustments on this carb and you need to alter the mounting angle of the carb to get fuel level about two thirds of the way up the jet chamber tube when boat is in normal trim. To do this remove float bowl,and refit with the jet chamber outside of its usual position so you can see the fuel. Turn fuel on and check level. Alter mounting angle of carb to adjust. There should be a slotted arrangement against the block to allow for altering the angle.
I also find that loading of the boat can effect the level and you need to be careful where your passengers go.
David Stott
timmulvey
Username: timmulvey
Post Number: 161
Posted on Tuesday, June 07, 2005 - 06:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I use a Champion L90C plug and found that it has been used on several others that I've got
