Blaxland twin in a 13 foot fiberglass...
Old Marine Engine » Blaxland » Blaxland twin in a 13 foot fiberglass boat « Previous Next »
Fred Thompson
Posted on Monday, June 02, 2014 - 03:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all would a blaxland twin fit in to a 13 foot boat or is this to small for this motor
Todd Vidgen
Username: todd_vidgen
Post Number: 255
Posted on Monday, June 02, 2014 - 05:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
waste of a motor.Hull speed would only be about 4 knots , and you could achieve that with a 3 1/2 single,plus the single with correct clutch is about 180 mm shorter = more room in small boat
Cheers Todd
Leigh Flanders
Username: leigh
Post Number: 13
Posted on Tuesday, June 03, 2014 - 03:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I,ve got a twin in a fourteen Fred ,,does 5.5 knts,,Give her a crack ,,,Todd not looking out of the square enough I think ,,
Ross Cook
Posted on Tuesday, June 03, 2014 - 03:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
if you have a twin and not a single, it should be alright, I have a twin in my fourteen footer too only because the price for the motor was too good to pass up
Andrew Munns
Username: johnoxley
Post Number: 119
Posted on Tuesday, June 03, 2014 - 04:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am restoring a C.A.M. Fisher 13'11" clinker commercial fishing boat still with the copper sheathing over the stbd bow gunwhale (assume for nets?). Planking is 1/2". Arrived minus engine, but original beds match the Blaxland twin I have.
Ross Cook
Posted on Tuesday, June 03, 2014 - 06:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
you have the motor, you have the boat. I don't see a problem, the twin won't sink it, just be overpowered, just don't use as much throttle, easy fix
