Comments on Evinrude inboard
Old Marine Engine » Unknown Engines - post here with photos » Comments on Evinrude inboard « Previous Next »
Ernest W Warner
Username: ewarn
Posted on Monday, August 20, 2007 - 08:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Could anyone please comment on the Evinrude pictured below. In particular, is it rare to have a distributor on a two cycle? There seems to be gear tying the flywheel rotation to the distributor. What vintage is this inboard? Where would I find information on this engine? Things like what kind of oil to use, is it a 6 volt system, and would a manual be available?
Evinrude
Roger DiRuscio
Username: solarrog
Post Number: 257
Posted on Monday, August 20, 2007 - 12:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This looks like the model DD, I have seen one other with a distributor inatalled. It is my belief that this is a field repair. vintage is early 20's. Your mileage may vary
Roger
Nigel
Posted on Tuesday, May 06, 2008 - 04:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI
Stumbled across your site and was intrigued to see an Evinrude Inboard,(model DD) I have one of these in the workshop, complete but stripped
There is a small crack in the water jacket on top of the engine but other than that it is OK, It also has a small gearbox bolted to the back end
Any info would be appreciated as it is on the list to restore it
Nigel
