Wico magneto replacement for Palmer B...
Old Marine Engine » Timers, Magnetos, Ignition » Wico magneto replacement for Palmer BH-25 « Previous Next »
robespierre222
Username: robespierre222
Posted on Monday, October 24, 2005 - 04:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would a Wico XH1295C, serial # is 410788 fit on a Palmer BH-25. The magneto I have (XH2058B) has damage to the case. Large chunk cracked out of it from the stop switch hole to the edge where cover begins. All the pieces are there, but i don't know if it can be fixed. I found an XH model on eBay and wondered if it could be adapted. I believe it comes from a John Deere. I would really rather repair mine, but....
Robes
Post Number: 598
Posted on Monday, October 24, 2005 - 06:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can clean the edges of the breaks and use JB Weld to fix yours. I don't know if the other mag will fit.
Hope this helps
robespierre222
Posted on Tuesday, October 25, 2005 - 09:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks, Ernie, I will definitely try that. Is there anything else I need to do to get it working at peak? What goes wrong with these magnetos?
Post Number: 602
Posted on Tuesday, October 25, 2005 - 04:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
These mags usually work real or not at all. I have had real good luck by cleaning the points real good. Take them out of the mag and file them if need be. Put them back in and set the gap. Around .020 i think. The condenser and coil rarely fail. When testing any mag or coil make sure you have some place for the spark to go. Never let it make spark to an open circuit. If you need a coil or condenser you can get them here.
http://www.magnetoparts.com/
In the process of cleaning your mag DO NOT remove the magnetic rotor.
Hope this helps
larry_from_maryland
Username: larry_from_maryland
Post Number: 275
Posted on Wednesday, October 26, 2005 - 07:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The point gap on the multi cylinder XH's is .014 to .016.Some Xh's can be reverse rotation.
richardday
Post Number: 474
Posted on Wednesday, October 26, 2005 - 07:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Make sure any replacement mag has the same rotation as the current mag. Not all mags can be made to run either direction.
robespierre222
Posted on Wednesday, October 26, 2005 - 08:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well, thanks guys. I have a very low bid in on that mag, so if I get it, not much lost. there was another new one that went for $122 on eBay 3 days ago. i had bid 120, but the winner nipped in at the last minute. Now i am glad I lost out, because I would much rather make the original work. Both the mags on eBay have the kill switch on the opposite side to the one I have now, so perhaps they are wrong. Just learning.
thanks again.
Victor Maessen
Username: mvictor_be
Post Number: 11
Posted on Sunday, June 10, 2007 - 07:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.magneto.co.uk/acatalog/Index.html
Victor Maessen
Post Number: 12
Posted on Monday, June 11, 2007 - 04:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Reconditioning Magneto staters .... http://www.ribblesdale.co.uk
