Magneto Flywheel Magnet Charging
Old Marine Engine » Timers, Magnetos, Ignition » Magneto Flywheel Magnet Charging « Previous Next »
Lee Henderson
Posted on Thursday, July 26, 2012 - 01:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am in the process of restoring a 1936 Johnson Model 300 Outboard 3.7 HP. I cannot get a spark or the spark is poor. The Coils, points and all the wiring seem fine but still no spark. I can bench test using a 1.5 Volt battery and get a spark but it still will not work as a magneto. It has a weak magnet so this may be the problem. My next step is to try to recharge the magnet. I would be very pleased if anyone has a charger that can do this.
The Flywheel inside diameter between the magnet pole shoes is 5 3/16 inches.
Lee Henderson
686 Thrush Court
Marco Island, FL 34145
EMail [email protected]
Phone: 239-389-5515
Cell Phone: 239-398-6481
Craig A. Mathews
Username: rustaholic
Post Number: 12
Posted on Thursday, July 26, 2012 - 01:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I can do it. But I'm in Los Angeles. I have had decent success with Maytag Flywheels and one Coldwell Cub Flywheel.
Craig A. Mathews
Post Number: 13
Posted on Thursday, July 26, 2012 - 01:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
P.S. Yes, that's the problem typically with a weak spark. Do you have access to a Gauss meter?
