Caille Perfection Single
Old Marine Engine » Caille » Caille Perfection Single « Previous Next »
Bill Nanfield
Posted on Wednesday, April 03, 2002 - 02:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Caille Perfection Single inboard with a Wico igniter type 01.The black & white adds I have show extensive "pinstripe" to cylinder,manifold & flywheel. Anyone know proper color combinations?? Any good detail photos from all sides!! Bill Nanfield
mechman
Posted on Thursday, April 04, 2002 - 08:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Goodday Bill --Here is a copy of art work from Caille catalog--Note there is no pin striping in this artwork /image{ Caille artwork}Good luck Larry Healey
Posted on Thursday, April 04, 2002 - 09:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Larry,
The "slash" should be the "backslash" \ instead of the "forwardslash" / that you used.... try again, you almost got it. If you have more trouble you can email it to me and I will post the picture, but I think you can get it.
Regards,
Andrew
mechman
Posted on Friday, April 05, 2002 - 07:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Goodday all--I'm still trying caille artworkLarry
Posted on Friday, April 05, 2002 - 07:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Good going Larry!
Very few marine engines had the type of "pinstriping" and elaborate paint detail that were common on farm and stationary engines.
Regards,
Andrew
