Dunn2 Valve Cage
Old Marine Engine » Dunn » Dunn2 Valve Cage « Previous Next »
doug11k
Username: doug11k
Post Number: 7
Posted on Tuesday, July 19, 2005 - 12:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here's a couple photos of intake valve cage made from Aermotor 8-cycle exhaust valve cage. Dimensions of casting dictated 1" npt inlet port(will probably bush it)and it is oriented in same direction as exhaust port. Will use elbow on exhaust port to eliminate interference with carburetor. I also had to use socket-head cap screws due to size of casting.Valve cageValve cage
